Spatially Enabled Dataframe
3969
01-16-2019 08:39 AM
OisinSlevin
Hi Guys,
Having an issue with a projection where the projection is off by 70 meters
example:
gis = GIS("url", "user", password)
content=gis.content.get("ID")
layers=content.layers
points=pd.DataFrame.spatial.from_layer(layers[0])
points['SHAPE']=points['SHAPE'].geom.project_as(29900)
my source data is in  EPSG:2157 but i need EPSG:29900, when I view the source data in an eternal package it aligns with the the backround map,
if I project to EPSG:29900 I'm roughly 70meters off from the basemap
if i project_as EPSG:4326 it seems to work with no issues and aligns with the base map.
Is there any known issues or any other ways to changing coordinate systems.
have had the same issue using spatial DataFrame and Spatially Enabled Dataframe.
I've also used geopandas to convert the data and that works perfectly so I'm nearly certain there is an issue.
simoxu
by MVP Alum
MVP Alum
I suspect the projection was done as expected.
Could you try this:
#points=pd.DataFrame.spatial.from_layer(layers[0])
#points['SHAPE']=points['SHAPE'].geom.project_as(29900)
feature_layer = layers[0]
fset = feature_layer.query(out_sr=29900)
sdf1 = fset.sdf
# then you can export the sdf1 as other formats if you like
The difference is the projection will be done on the server rather than in the browser, at least this is what I am guessing
JoshuaBixby
Is it just between EPSG:2157 and EPSG:29900 or can you reproduce between other combinations?  Also, what if you try from EPSG:2157 to EPSG:29902 ?  According to several sites, EPSG:29900 is deprecated, so maybe that is causing an issue with the transformation.
OisinSlevin
I've tried using 29902, I've also tried converting from 2157 to 4326, and then projecting to 29902, so I think its just an issue with the projection to 29902.
simoxu
by MVP Alum
MVP Alum
Could you try this:
sdf1 = fset.sdf
OisinSlevin
Thanks this fixes my issue, although I'm still concerned if projections don't match ?
