Python value variable in SQL expression FeatureLayer.query(where = "attributeName = 'StringValue'" )
3318
5
09-13-2022 03:11 AM
AngelRomoSandoval
I am trying to insert a variable where ClientName is written:
Fl_Filtered = FeatureLayer.query(where = "client = 'clientName'")
I tried this without success:
querytxt = 'where = "KundeName = ' + "'" + ""'%s'"" %kundeNameWhereFilter + "'" + '"'
Print(querytxt)
Fl_Filtered = FeatureLayer.query(querytxt)
The print ist returns the right String but the query returns an Error code: 400
 Anyone knows how could be the solution?
Clubdebambos
MVP Regular Contributor
Hi @AngelRomoSandoval
I like to use the string format, there are various options, see here.
The example below uses numbered indexes.
## example 1
client_name = "My Clients Name"
Fl_Filtered = FeatureLayer.query(where = "client = '{0}'".format(client_name)
### DO SOMETHING WITH THE CLIENT
## example 2
client_list = ["Client 1", "Client 2", "Client 3"]
for client_name in client_list:
### DO SOMETHING WITH EACH INDIVIDUAL CLIENT
also, how are you accessing the Feature Layer?
from arcgis import GIS
agol = GIS("home")
feature_service = agol.content.get("***ITEM_ID***")
feature_layer = feature_service.layers[0] # where 0 is the index of the first layer in the featire service
Fl_Filtered = feature_layer.query(where = "client = '{0}'".format(client_name)
~ learn.finaldraftmapping.com
Clubdebambos
## example 1
## example 2
agol = GIS("home")
AngelRomoSandoval
Yes, I access with the Item Id.  Thank you for all the examples!
DavidAnderson_1701
Be careful when doing this if the variable value is coming from an outside source.  A SQL injection attack could be done.   Before deploying the simple solution read a bit more about SQL injection attacks and how to defend your code against them.  Here is one source, https://realpython.com/prevent-python-sql-injection/, many others to consult.
AngelRomoSandoval
Thank you for the info, no, it comes not from an external source. I will keep it in mind.
KimOllivier
Honored Contributor
There is already a function to validate the SQL string built in to the API. Very straightforward.
https://developers.arcgis.com/python/api-reference/arcgis.features.html#arcgis.features.FeatureLayer...
