Layer to Shapefile
1813
02-16-2022 07:28 AM
arashhokm
Hallo Esri Community,
I would like to convert and export my layers to File GDB.
In ArcMap I can export the layer as a feature class with a right click.
I'm trying to automate this process using Arcpy.
I get an error message when running my script.
I use SQL Server and ArcSDE as database.
I would be grateful if you could suggest me a solution.
Below you will find my script, error message and the image of the layer.
MehdiPira1
Hi @arashhokm ,
You're missing a backslash in your out variable for the path:
this should be like:
out = r"I:\2022\Shapefile\FGDB\Wasser.gdb"
