Installing arcgis-map-ipywidget in Jupyter Lab
2045
10-04-2023 01:50 PM
Labels (2)
RikBosman
The Esri documentation that describes how to install Jupyter Labs is very clear on the version of the arcgis-map-ipywidget.
  • NOTE: your installed ArcGIS API for Python version must EXACTLY match this installed arcgis-map-ipywidget npm jupyterlab extension, or else it will not work. (ex. 1.8.2 of the Python API installed, 1.8.2 of the arcgis-map-ipywidget extension installed. jupyter labextension list will show you all versions of extensions installed)
However, since I installed the latest API (conda list indicates 2.2.0) I would have expected to find the also the 2.2.0 version of the arcgis-map-ipywidget while configuring the extensions in jupyter lab (Browser). How do I install the correct version? The command jupyter labextension list gives arcgis-map-ipywidget v1.8.1 enabled OK
Thanks for your help!
BrandoCrozier
@RikBosman did anyone ever help you with this?
