IndexError: list index out of range when using variable
4693
08-10-2022 06:38 AM
WhitneyWeber
I am following the example within Editing Features: to select a feature within the feature layer.
sfo_feature = [f for f in ports_features if f.attributes['port_name']=='SAN FRANCISCO'][0]
The code is successful when hard-coding the value, as with 'SAN FRANCISCO' above, but fails with IndexError: list index out of range when using a variable. Following is my code:
The following is successful:
obs_feature = [f for f in obs_features if f.attributes['globalid']=='18d8c3ac-f828-4d93-b4e8-8a3b281f1790'][0]
And, the following is successful:
globalid = '18d8c3ac-f828-4d93-b4e8-8a3b281f1790'
obs_feature = [f for f in obs_features if f.attributes['globalid']==globalid][0]
The following fails, with IndexError: list index out of range when using a variable.  I know the value is correct via the use of AddMessage to know the value being queried:
globalid = "'"+original_globalid+"'"
arcpy.AddMessage("globalid: {}".format(globalid)+"; fld: {}".format(fld)+"; fld_value: {}".format(fld_value))
I assume this is something simple, but can't figure out the problem. I've tried format(globalid), although that shouldn't be necessary, but that fails as well.
Someone, please save me from myself!
KenBuja
MVP Esteemed Contributor
Isn't original_globalid already a string with quotes? Are you putting an extra set of quotes around the string?
KenBuja
WhitneyWeber
Sorry, no, it's not already a string with quotes. . I should have put the result of the AddMessage:
globalid: '18d8c3ac-f828-4d93-b4e8-8a3b281f1790'; fld: EO_ID; fld_value: 300997.0
So, you can see the globalid from the AddMessage is the same as what was hardcoded in the code that works. It just doesn't work when using the variable.
KenBuja
However, note that the fld value is also a string and doesn't have quotes.
WhitneyWeber
You're a genius! I was obviously over-thinking this. Thank you so much! It always helps to have someone else's view.
