I'm trying to set the AGOL utility services used by a Portal using the Python API. After setting them up through the Portal UI, I can see that the URL to the AGO World Closest Facility service, for example, is:
https://<domain>/portal/sharing/servers/7f5b6ab8ac444bf685520f0e642079c8/rest/services/World/ClosestFacility/NAServer/ClosestFacility_World
but I also know that my login credentials are used to access the AGOL services, and I'm assuming that they're encrypted in the ID portion of the URL (the portion between /servers/ and /rest/). So, if this is the case, can I assume that this URL can be used to access the utility services, provided that the login credentials remain invalid? In that case, I can use the
GIS<SPAN class="punctuation token">.</SPAN>update_properties<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
method to pass in a dictionary representing the utility services. Or, is there another place in the API that I can set the AGOL utility services by passing in the login credentials?
