how to add multiple filters using query() of feature layer
1680
05-09-2024 07:24 AM
Manager_HMWSSBCDC
time = f"closingdate >= DATE '{from_date_str}' AND closingdate <= DATE '{to_date_str}'"
value = 'MCC'
field_filter = f"trip_name == '{value}'"
query_filter = f"{time_filter} AND {field_filter}"
# Query the feature layer
query_result = tankers.query(where=f"trip_name = 'MCC' AND time_filter={time}")
Can anyone suggest what's wrong in the above code.
RPGIS
by MVP Regular Contributor
Which language is this? I want to say python, but it is hard to tell from the looks of it.
If it is python, then you would need to adjust your dates to be equivalent to the following:
from datetime import datetime
FromDate = <FromDateField>.isoformat(timespec='seconds')
ToDate = <ToDateField>.isoformat(timespec='seconds')
time = f"closingdate >= {FromDate} AND closingdate <= {ToDate}"
query_result = tankers.query(where=f"trip_name = {'MCC'} AND {time}")
Manager_HMWSSBCDC
Thanks for the reply. I wrote this using ArcGIS API Python
I followed according to your code:
portal_item = gis.content.search(query="title:tankers", item_type="Feature Layer")
flayer = portal_item[3]
tankers = flayer.layers[0]
# Convert the string to a datetime object
FromDate = datetime.strptime(from_date_str, '%d-%b-%Y').isoformat(timespec='seconds')
ToDate = datetime.strptime(to_date_str, '%d-%b-%Y').isoformat(timespec='seconds')
But I got the following error message:
Exception: Unable to complete operation.
Query with count request failed.
(Error Code: 400)
 where as in documentation, the syntax is different
query(where="trip_name='MCC'",time_filter=[<start_time>,<end_time>)
I tried the above one too, its not throwing any error but considering only first parameter in where clause not considering time_filter parameter.
MarkKinnaman
Try the code below as I believe the time_filter parameter wants a datetime object and when you use isoformat it converts it to a string.
query_result = tankers.query(where=f"trip_name = {'MCC'},time_filter=[FromDate, ToDate])
RPGIS
You do not need to use the datetime.strptime() function since python will automatically convert a datetime python object to a sql datetime object when you specify the actual datefield.
Sample = datetime.now().isoformat(timespec='seconds')
print( Sample )
#printed result = '2024-05-13T08:42:27'
