How draw lines between two point?
5305
8
03-19-2021 12:00 AM
Radzhabasda
I try draw line between points, but on map i dont see results
input_table = r"C:\Users\Admin\table.csv"
out_lines = r"C:\Users\Проект.gdb\Результат"
#XY To Line
arcpy.management.XYToLine(input_table,out_lines,
                         "LOND1","LATD1","LOND2",
                         "LATD2","GEODESIC","idnum")
table.csv
idnum;LOND1;LATD1;LOND2;LATD2
1;47.43388800000008;42.983686000000034;47.43402500000008;42.98425700000007
2;47.43412900000004;42.98377300000004;47.43314600000008;42.981682000000035
3;47.433530000000076;42.983711000000085;47.43436800000006;42.985129000000086
Tags (4)
nita14
check if out_lines are automatically added to to the map. If not add it from your .gdb. Next, right click the layer and choose Zoom to Layer. Check the attachment below.
BR,
Adam
Radzhabasda
Outline is not created. How it create?
nita14
What do you mean by outline? You can change the symbology as the respective ArcGIS Pro tab.
Radzhabasda
Sorry, no outline. I mean - feature out_lines is not created on map
Radzhabasda
I not see this feature in project
nita14
ok. In ArcGIS Pro/ ArcMap Catalog window, navigate to
C:\Users\Проект.gdb
 Do you see Результат? If yes, drag and drop it into your map window.
DanPatterson
MVP Esteemed Contributor
XY To Line (Data Management)—ArcGIS Pro | Documentation
requires a table of the appropriate structure
it won't take a semi-colon separated csv file as input, you need to make convert it into a geodatabase table first
... sort of retired...
Radzhabasda
Add some changes. Code works, but in arcgis i dont see changes
# -*- coding: utf-8 -*-
import arcpy
import os
import json
arcpy.env.workspace = r"C:\Project.GDB"
from arcpy import env
featureList = []
out_lines = r"C:\Project.GDB\Результат"
