GIS module does not access ArcGIS Hub
4720
12
10-13-2022 08:25 AM
JaredPilbeam2
I can use the GIS module on our organization's Community Hub site.
rom arcgis.gis import GIS
gis = GIS("https://willcounty.maps.arcgis.com/", "user", "password")
 But, I can't on ArcGIS Hub. This attempt is from an anaconda environment. I also tried from an Pro environment and got same error.
from arcgis.gis import GIS
gis = GIS("https://willcountygis.hub.arcgis.com/", "username", "password")
#Error:
JSONDecodeError                           Traceback (most recent call last)
<ipython-input-5-0190cb412727> in <module>
      1 from arcgis.gis import GIS
----> 2 gis = GIS("https://willcountygis.hub.arcgis.com/", "username", "password")
c:\ProgramData\Anaconda3\envs\py37\lib\site-packages\arcgis\gis\__init__.py in __init__(self, url, username, password, key_file, cert_file, verify_cert, set_active, client_id, profile, **kwargs)
    481                 )
    482             else:
--> 483                 raise e
    484         try:
    485             if (
    442                 trust_env=kwargs.get("trust_env", None),
    443                 timeout=self._timeout,
--> 444                 proxy=kwargs.get("proxy", None),
    445             )
    446             if self._portal.is_kubernetes:
c:\ProgramData\Anaconda3\envs\py37\lib\site-packages\arcgis\gis\_impl\_portalpy.py in __init__(self, url, username, password, key_file, cert_file, expiration, referer, proxy_host, proxy_port, connection, workdir, tokenurl, verify_cert, client_id, custom_auth, token, **kwargs)
    203                 )
    204         # self.get_version(True)
--> 205         self.get_properties(True)
    206
    207     def add_group_users(self, user_names, group_id, admin_names):
c:\ProgramData\Anaconda3\envs\py37\lib\site-packages\arcgis\gis\_impl\_portalpy.py in get_properties(self, force)
   1225                     )  # issue seen with key, cert auth
   1226                 if not resp:
-> 1227                     raise e
   1228
   1229             if resp:
   1205             resp = None
   1206             try:
-> 1207                 resp = self.con.post(path, self._postdata(), ssl=True)
   1208             except Exception as e:
   1209                 if (
c:\ProgramData\Anaconda3\envs\py37\lib\site-packages\arcgis\gis\_impl\_con\_connection.py in post(self, path, params, files, **kwargs)
    964                     params.pop("token", None)
    965                     # pass
--> 966             elif token_as_header == False and self.token is not None:  # as ?token=
    354         except StopIteration as err:
--> 355             raise JSONDecodeError("Expecting value", s, err.value) from None
    356         return obj, end
JSONDecodeError: Expecting value: line 1 column 1 (char 0)
According to the GIS Module help docs it doesn't look like you can access Hub. Is there any other way?
GIS : represents the GIS, either ArcGIS Online or an ArcGIS Portal
ManushiMajumdar
@JaredPilbeam2you are running into an error because you are signing into your Hub site. You need to sign into your Hub organization (as you have shown in the first code snippet) and then access your sites using the gis.hub submodule of the ArcGIS API for Python.
Alternatively, you can also use Hub's Python API https://github.com/Esri/hub-py/ but you will still need to sign into your Hub (org) and then fetch the particular site you wish to work with.
BrodyNienow
I also cannot access the ArcGIS Hub. Maybe its a glitch. Hopefully, it will get right soon.
Brian_Wilson
Honored Contributor
The web page for hub.arcgis.com has no meaning to me, it says it will "allow people ... to accomplish ... goals"
Hard to get excited enough to try logging in.
Brian_Wilson
Honored Contributor
I tried anyway -- I can log in fine using my AGO credentials in a browser but via arcgis.gis fails for me too.
Is Hub just a different UI for AGO?
JaredPilbeam2
No, it's meant to be a more collaborative environment than AGOL. Hub overview.
Brian_Wilson
Honored Contributor
Sorry I was not clear -- the real question is, isn't it just exposing the content in your *.maps.arcgis.com account? So if you want to manipulate your content then you can use the regular AGOL login and its API. If there are very specific things that hub gives you beyond a different UI, then you'd be out of luck.
STOP READING HERE. 🙂
When I tried Hub I was shown content in my AGOL account, in a different format, shrugged, and moved on because I still had not "transformed my community" and it was already Wednesday.
The Hub Overview is the one I referenced above but thanks, I need more than that. Whoever designed it had no idea what Hub is, so they turned the crank on the hype machine and cranked out content-free sentences like "With ArcGIS Hub, organizations can leverage their existing data and technology and work together with internal and external stakeholders to track progress, improve outcomes, and create vibrant communities."
Excuse me now, I have to go get me some leverage, my community is insufficiently vibrant.
ManushiMajumdar
JaredPilbeam2
Hi @ManushiMajumdar ,
I have no problems accessing sites on our organization's Hub Community using either module here:
gis = GIS("https://willcounty.maps.arcgis.com", "adminUsername", "password")
sites = str(gis.content.search(query="", item_type="Site", sort_order="asc"))
or
from arcgishub import hub
myHub = hub.Hub("https://willcounty.maps.arcgis.com", "adminUsername", "password") # or the url of your ArcGIS Online organization
initiatives = myHub.initiatives.search()
They both give me the same sites:
[<Initiative title:"Capital Project Tracking" owner:WillCoHub>,
<Initiative title:"testDelete" owner:jpilbeam_hub>,
<Initiative title:"DeciPH-ER " owner:WillCoHub>]
That's what I'm after is our stuff on the Hub site: https://hub.arcgis.com. Is that possible with the Python API? That's my question. We have 900+ items.
ManushiMajumdar
To access all the items in your Hub (organization), you will need to use the `gis.content` submodule of the ArcGIS API for Python.
JaredPilbeam2
Yes, unless I'm completely missing something I can not access the content on our https://hub.arcgis.com page using any module or submodule.
