Export ArcGIS spatially enabled dataframe to feature class
4525
04-04-2022 01:16 PM
jcroff
I'm working to develop a tool that converts JSON data pulled from an API into a feature class to be stored in an ESRI file geodatabase. I'm currently testing the functionality in a Jupyter notebook within an ArcGIS Pro project but my goal is to eventually convert my script into a geoprocessing tool that can be used by non-developer users. However, I've gotten stuck in the prototype phase and cannot figure out if I am running into a bug or if there is an issue with my code.
Here is my code:
import requests
import arcpy
from arcgis.features import GeoAccessor, GeoSeriesAccessor
import pandas as pd
# pull public geojson data from socrata
r = requests.get('https://data.bayareametro.gov/resource/ufzj-38uk.json')
j = r.json()
df = pd.DataFrame.from_dict(j)
# Convert to Spatially Enabled Pandas Dataframe
sedf = pd.DataFrame.spatial.from_df(df, geometry_column='shape')
# Export Spatially Enabled Pandas Dataframe to FGDB Feature Class
sedf.spatial.to_featureclass(location='equity_priority_areas_2020')
This is the error message I received:
ValueError Traceback (most recent call last)
In [22]:
Line 5: sanitize_columns=True)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\geo\_accessor.py, in to_featureclass:
Line 2388: has_m=has_m,
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\geo\_io\fileops.py, in to_featureclass:
Line 853: df.columns = original_columns
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\generic.py, in __setattr__:
Line 5478: return object.__setattr__(self, name, value)
File pandas\_libs\properties.pyx, in pandas._libs.properties.AxisProperty.__set__:
Line 66:
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\generic.py, in _set_axis:
Line 670: self._mgr.set_axis(axis, labels)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\internals\managers.py, in set_axis:
Line 221: f"Length mismatch: Expected axis has {old_len} elements, new "
ValueError: Length mismatch: Expected axis has 42 elements, new values have 41 elements
Here is what I tried to resolve the issue:
I reviewed the GeoAccessor class method [to_featureclass](https://developers.arcgis.com/python/api-reference/arcgis.features.toc.html#arcgis.features.GeoAcces...) API reference and tried to set the path to the File Geodatabase explicitly as well as provide explicit values for the `has_z`, `haz_m`, and `sanitize_columns` parameters as shown below and got the same error message.
sedf.spatial.to_featureclass(location='Z:\Documents\ArcGIS\Projects\Socrata_to_ArcGIS\Socrata_to_ArcGIS.gdb\equity_priority_areas_2020',
overwrite=True,
has_z=False,
has_m=False,
I seem to always run into issues when trying to perform seemingly basic things with these spatially enabled dataframes.
jcarlson
Someone else recently posted about this same (or at least a very similar) issue: https://community.esri.com/t5/arcgis-api-for-python-questions/my-agol-notebooks-are-not-working/m-p/...
Do you have any other Python envs where you could try the same code? If it doesn't actually need arcpy, there's no reason you can't run this sort of thing elsewhere.
- Josh Carlson
Kendall County GIS
jcroff
Yeah I just took a look at that post. I do have other environments but ultimately, I'm going to turn this script into a geoprocessing tool for non-programmer ArcGIS Pro users to use to pull in layers from our Socrata data portal. Also, I'm not sure that you can write to file geodatabases without arcpy, correct?
jcarlson
By default, no. If you want to write to a file geodatabase from outside of arcpy, you've got to download the File Geodatabase API and get that set up on your system.
https://github.com/Esri/file-geodatabase-api/
There's a separate space for the FGDB API here on the Community, too! Not incredibly active, but you can see how other folks are using this.
https://community.esri.com/t5/file-geodatabase-api/ct-p/file-geodatabase-api
- Josh Carlson
Kendall County GIS
apnpgc
Hi all, Can someone please clear me the below post mentioned:
https://community.esri.com/t5/file-geodatabase-api/ct-p/file-geodatabase-api-apnpgc
I am little bit confused about the API.
