I just upgraded to ArcGIS Portal 11.1, and now clone_items() doesn't work. Here is an example:
AttributeError Traceback (most recent call last)
~\AppData\Local\Temp\ipykernel_17668\1636443366.py in <cell line: 1>()
----> 1 cloned_items = target_gis.content.clone_items(items=[item], preserve_item_id=True)
2 cloned_items
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py in clone_items(self, items, folder, item_extent, use_org_basemap, copy_data, copy_global_ids, search_existing_items, item_mapping, group_mapping, owner, preserve_item_id)
7887 preserve_item_id = False
7888
-> 7889 deep_cloner = clone._DeepCloner(
7890 self._gis,
7891 items,
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py in __init__(self, target, items, folder, item_extent, service_extent, use_org_basemap, copy_data, copy_global_ids, search_existing_items, item_mapping, group_mapping, owner, preserve_item_id)
106 self._temp_dir = tempfile.TemporaryDirectory()
107 # parse the config and get values
--> 108 self._create_graph()
109 self._cloned_items = []
110
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py in _create_graph(self)
118 user = self.target.users.me
119 # Get the definitions associated with the item
--> 120 self._get_item_definitions(item)
121
122 # Test if the user has the correct privileges to create the items requested
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py in _get_item_definitions(self, item)
987 # All other types we no longer need to recursively look for related items
988 else:
--> 989 item_definition = self._get_item_definition(item)
990 self._graph[item.id] = item_definition
991
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py in _get_item_definition(self, item)
1611 )
1612
-> 1613 return _WebExperience(
1614 self.target,
1615 self._clone_mapping,
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_itemdef\_expbuilder.py in __init__(self, target, clone_mapping, info, data, sharing, thumbnail, portal_item, folder, item_extent, search_existing, owner, **kwargs)
25 **kwargs,
26 😞
---> 27 super().__init__(target, clone_mapping, search_existing)
28 self.info = info
29 self._preserve_item_id = kwargs.pop("preserve_item_id", False)
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py in __init__(self, target, clone_mapping, info, data, sharing, thumbnail, portal_item, folder, item_extent, search_existing, owner, **kwargs)
1987 self.item_extent = item_extent
1988 self.created_items = []
-> 1989 self.metadata_xml = portal_item.metadata
1990
1991 @property
AttributeError: 'NoneType' object has no attribute 'metadata'
