Calculate Field with Functions & values from other Fields
800
03-18-2024 10:58 AM
usace_sam_rd3
I'm sure I'm missing something simple.  I am just trying to use the API for python to update attributes using functions and values from other fields; but haven't been successful in formatting the the statement correct.
def getTotalDays(load,start):
 delta = load-start
 days = delta.days
 if days ==0:
  return 1
 else:
  return days
calc_dict['field'] = 'totaldays'
#This is not correct:
calc_dict['sqlExpression'] = 'getTotalDays(!{0}!,!{1}!)'.format("dateloadedenterprise","surveydatestart")
result = compliance_svc_lyr.calculate(where=where,calc_expression=calc_dict)
Additionally, I previously used dataframes to update the service, however had the same error as noted in this post, so I'm resorting back to field calculations.
