Bug in Python API 1.8.1
1525
10-26-2020 06:26 PM
FraserHand
I think there is a bug in the Python API.
When creating a new Table feature and adding it to a webmap I get an error:
AttributeError("'NoneType' object has no attribute 'json'",)
using something like
new_table = Table(new_table_url)
wm.add_table(new_table)
in the add_table function in C:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\mapping\_types.py we have
if not isinstance(table, arcgis.features.Table):
raise Exception("Type of object passed in must of type 'Table'")
self.add_layer(table, options)
in  def add_layer(self, layer, options=None):
the first check is
if options is None:
options = {}
if isinstance(layer, arcgis.features.FeatureLayer) and \
'renderer' not in options:
options['renderer'] = json.loads(layer.renderer.json)
which throws the error because tables obviously don't have renderers.
If you do this
True
isinstance(table, arcgis.features.FeatureLayer)
True
which is why it doesn't work.
DanPatterson
You might want to see if that issue has been address with version 1.8.2, otherwise raise an "Issue" at
GitHub - Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python
... sort of retired...
