Dear community,
does anyone has an idea why my connection to ArcGIS Online will fail behind a proxy?
This is the Python command I am trying:
>>> from arcgis import GIS
>>> gis = GIS(proxy_host="myproxy.myorg.at", proxy_port=3128, url="https://myorg.maps.arcgis.com/", username="user", password="password")
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 696, in urlopen
self._prepare_proxy(conn)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 964, in _prepare_proxy
conn.connect()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connection.py", line 359, in connect
conn = self._connect_tls_proxy(hostname, conn)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connection.py", line 506, in _connect_tls_proxy
ssl_context=ssl_context,
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\util\ssl_.py", line 450, in ssl_wrap_socket
sock, context, tls_in_tls, server_hostname=server_hostname
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\util\ssl_.py", line 493, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\ssl.py", line 423, in wrap_socket
session=session
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\ssl.py", line 870, in _create
self.do_handshake()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\ssl.py", line 1139, in do_handshake
self._sslobj.do_handshake()
OSError: [Errno 0] Error
During handling of the above exception, another exception occurred:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\adapters.py", line 449, in send
timeout=timeout
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 796, in urlopen
**response_kw
**response_kw
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\connectionpool.py", line 756, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\urllib3\util\retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='tiwag.maps.arcgis.com', port=443): Max retries exceeded with url: /sharing/rest/generateToken (Caused by ProxyError('Cannot connect to proxy.', OSError(0, 'Error')))
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1036, in post
url=url, data=params, cert=cert, files=files, timeout=timeout
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\sessions.py", line 590, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\adapters.py", line 510, in send
raise ProxyError(e, request=request)
requests.exceptions.ProxyError: HTTPSConnectionPool(host='tiwag.maps.arcgis.com', port=443): Max retries exceeded with url: /sharing/rest/generateToken (Caused by ProxyError('Cannot connect to proxy.', OSError(0, 'Error')))
File "<stdin>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 483, in __init__
raise e
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 444, in __init__
proxy=kwargs.get("proxy", None),
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 205, in __init__
self.get_properties(True)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 1227, in get_properties
raise e
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 1207, in get_properties
resp = self.con.post(path, self._postdata(), ssl=True)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 966, in post
elif token_as_header == False and self.token is not None: # as ?token=
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1447, in token
self._token = self._enterprise_token()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1591, in _enterprise_token
res = self.post(path=self._token_url, params=postdata, add_token=False)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1050, in post
"A connection error has occurred: %s" % errCE
requests.exceptions.ConnectionError: A connection error has occurred: HTTPSConnectionPool(host='tiwag.maps.arcgis.com', port=443): Max retries exceeded with url: /sharing/rest/generateToken (Caused by ProxyError('Cannot connect to proxy.', OSError(0, 'Error')))
