ArcGIS API Python - script to see what data is linked to what maps to what apps
4964
9
10-15-2018 12:06 PM
JoshuaChan2
#notAnsweredYet
is there a script to see what feature services are linked to which web maps which are linked to which apps within your account?
I vaguely remember seeing a demo of this by John Yaist and David Martinez during the ESRI Conference in San Diego this year. But for the life of me I'm unable to find the code anywhere.
The idea is that I have a story map journal, and i'd like to create a list to see which of my AGO web maps are attached to that story map. And to go one level further, to see what feature layers are used in those AGO web maps.
The demo created a text file - or maybe an excel sheet - of that - which is exactly what I was looking for.
JoshuaChan2
P.S. i accidentally hit the button that said "Assumed Answered" but I don't know how to turn that off.... help?
JohnYaist1
Hi Joshua Chan
The attached script is what we showed in San Diego. Let me know if you have any questions.
JoshuaChan2
thanks. I'll have a look
is ipynb only viewable in Jupyter notebook?
JoshuaChan2
hi John
I took a look and so far so good... but I have an account on a different subscription (https://governmentofbc.maps.arcgis.com/home/signin.html ) that requires me to use a different log in. How do I access it via the "BCGOV" button instead of the usual ArcGIS Online login?
JohnYaist1
If I understand you correctly, Chan , you're asking about how you connect through the API using the authentication scheme of your organization. Take a look at the Working with different authentication schemes guide to find out which scheme you're using. The syntax for connecting with the scheme should be illustrated in the guide.
Mannus_Etten
I have built a windows wpf-tool for this
Portal Genius / KLIC Genius / Backup Genius
JyrkiSaarnio
List of layers that has been added to webmap works fine, but is there anyway to list webmaps that has been used in web mapping application?
PhilippeRieffel1
Could you use the "related_items" method, as outlined here?
arcgis.gis module — arcgis 1.5.1 documentation
Mannus_Etten
the related_items doesn't work properly. We from the Right Direction developed a friendly product with a friendly user interface to see those relationships. The product is called Portal Analyzer (http://www.portalanalyzer.com). Unfortunately in Dutch but email me with questions or a demo.
Figuring out the relationships is quit a mess and complex.
