ArcGIS API for Python in Visual Studio Code not showing maps
4770
02-26-2021 03:27 AM
MarkusSchenardi
I'm trying to display a map inside a jupyter notebook running in Visual Studio Code (with the python and jupyter extension enabled).
Environment is Python 3.7 or 3.8 and arcgis (API for python) 1.8.4.
I created a new conda env as described here: https://support.esri.com/en/technical-article/000022005
Code
The code is very simple in Jupyter:
from arcgis import GIS
gis = GIS(url='https://<abc>.maps.arcgis.com',username='<username>',password='<pwd>')
mymap=gis.map('Zurich')
mymap
PROBLEM
As soon as a map should be displayed in the widget a white box appears with:
Unhandled Error! See the browser console.
console warningconsole warning
Messages in the console:
[Embedded Page] WidgetManager: Loading class LayoutModel:@jupyter-widgets/base:1.2.0
webviewElement.ts:90 [Embedded Page] require promise
webviewElement.ts:90 [Embedded Page] WidgetManager: Loading class ArcGISMapIPyWidgetModel:arcgis-map-ipywidget:1.8.4
webviewElement.ts:90 [Embedded Page] Fetch IPyWidget source for arcgis-map-ipywidget
webviewElement.ts:90 [Embedded Page] WidgetManager: Loading class LayoutModel:@jupyter-widgets/base:1.2.0
webviewElement.ts:90 [Embedded Page] WidgetManager: Loading class ArcGISMapIPyWidgetView:arcgis-map-ipywidget:1.8.4
webviewElement.ts:90 [Embedded Page] WidgetManager: Loading class LayoutView:@jupyter-widgets/base:1.2.0
webviewElement.ts:90 [Embedded Page] Error on render:
webviewElement.ts:90 [Embedded Page] Error: Script error for "esri/Map"
https://requirejs.org/docs/errors.html#scripterror
* The same code runs without problems in condas jupyter notebook
* The same code also runs in VS Code when using the conda environment installed with ArcGIS Pro
Any suggestions how to fix this problem?
DanPatterson
MVP Esteemed Contributor
You might want to post an issue on their github site
Issues · Esri/arcgis-python-api (github.com)
... sort of retired...
MarkusSchenardi
