Access to arcgis.gis from a computer where Pro is not installed
2026
03-31-2021 08:16 AM
MingHome
Dear Community,
We have ArcGIS Enterprise license and Pro installed on a number PCs. Usually, we run our Python scripts and get ArcGIS API for Python libraries from "...\Pro\bin\Python\envs\arcgispro-py3\python.exe".
Issue: Now, I want to execute a script from a PC where Pro is not installed (set an auto-run on schedule using Window's scheduling program and need to access some data on that PC). Can I do this? And How?
Ming
JoshuaBixby
JoshuaBixby
MingHome
Thanks for the reply and I will give a test ASAP!
Will it work if I just simply copy the "C:\Program Files\ArcGIS\Pro\bin\Python" folder (including all the sub folders) from a PC to this PC?
Ming
jcarlson
MVP Alum
You'll probably want to give it a fresh install to avoid issues. Plus for a python environment separate from Pro, you can pare down the installed modules and save space.
- Josh Carlson
Kendall County GIS
MingHome
Got it!
Thanks!!
