Position of circle geometry
1896
12-16-2017 11:31 AM
EvonFranklin
I can get the mapPoint or screenPoint of a circle geometry, however after moving or panning the map i want to get the new screen coordinates in relation to the circle geometry and its screen position. Is this possible?
Tags (1)
RobertScheitlin__GISP
Evon,
   If I am understanding your question. Yes you can get the screen coordinates of any map point using the maps toScreen method:
https://developers.arcgis.com/javascript/3/jsapi/map-amd.html#toscreen
Evon,
EvonFranklin
I will look over that link thanks Robert. I currently have a Circle geometry added to the map when you click which is suppose to highlight some Points, but when I check the coordinates for the circle they stay the same even after panning the map, I want to get the new coordinates as it relates to position on the screen after you pan, so it might be at X:100 , Y: 150 on initial click then when you pan the map the the left the screen position of 'X' should change right? Or will it stay the same X,Y as before?
EvonFranklin
I was trying to use the Map object instead of MapView at one point after following your link but that does the trick thanks!
