popup style from sceneview editor
1981
04-27-2021 07:14 PM
rcwisc
Is it possible to get the popup style from the sceneview editor? I much prefer this to the standard popup. This seems only available in the sceneview editor or is it available somewhere else? Attached is a screenshot of what I am referring to. Thanks!
KristianEkenes
This is the default popup style in the 4x versions of the JS API. By "standard popup" do you mean the popup in the class map viewer (3x JS API)?
If you want to take advantage of this in webmaps you can use it in any JS API 4x app, or in the map viewer beta.
rcwisc
Hello @KristianEkenes
I am using version 4.18 but my popup  does not look like the picture I posted in the example. Mainly what I am looking for is to have a single large popup action button on the bottom of my popup like in the sceneview popup picture I posted where the 'zoom to' action is a large green button. My popup has small action icons I have attached a screenshot. What am I doing wrong?
RalucaNicola1
Hey,
there is no out of the box style similar with the SceneViewer one, you'll have to do all the styling yourself.
Here is some basic css that the sceneviewer also uses, to get you started: https://codepen.io/ralucanicola/pen/poRMagR?editors=1000
This UI style guide might also be helpful to figure out how to style widgets: https://developers.arcgis.com/javascript/latest/styling/
