How to enable a popup for a OGCFeatureLayer
1605
09-30-2020 10:29 AM
julienrobitaille
Hello,
From the documentation, to enable a popup using the OGCFeatureLayer you first need to set popupEnable to true, and either set Popup.defaultPopuTemplateEnabled to true or use your own template. I have tried bith things, neither of them work. When I click on a feature in the map, nothing is happening.
Here is the relevant section of my code:
            Popup.defaultPopupTemplateEnabled = true;
            var layer_marais = new OGCFeatureLayer({
                url: "http://localhost:32769/geoserver/ogc/features/",
                collectionId: "OGSL:marais_pointe-fortin_ichtyo_longt_2019",
                legendEnabled: true,
                popupEnabled: true,
Anybody have the same issue, or could help me with it?
Thanks in advanced!
ReneRubalcava
Esri Frequent Contributor
It looks like this works in the next version of the API, so will work in 4.17 release.
https://codepen.io/odoe/pen/KKzLLgP?editors=1000
ReneRubalcava
julienrobitaille
Yes, it does work with the 4.17.
Thank you!
