Export Map
6270
14
07-28-2012 06:12 AM
VenkatChakaravarthy
I am wondering if there is any way to save the map (as jpg or png or gif or tiff ) when the map is loaded in the browser. I am trying to avoid the user click to export the map after the map is loaded. I have attached a sample map.
Thank you for reading this and I appreciate any advise.
VenkatChakaravarthy
Use the print widget or the print task. Here's a simple sample showing how to use the print dijit.
Thank you Derek. I will try this and get back to you with questions.
VenkatChakaravarthy
Thank you Corey. I will try this and get back to you with questions.
VenkatChakaravarthy
Thank you Mostafa. I will try this and get back to you with questions.
VenkatChakaravarthy
Thank you Rahul. I will try this and get back to you with questions.
VenkatChakaravarthy
I have attached a geosearch sample map generated with  javascript api.
Any reason why the point is away from the actual address?
Thank you.
