esriId.registerToken is not a function
3068
08-17-2017 04:50 AM
KostasPapakonstantinou
Hello,
I try to register a token I have created, using IdentityManager.registerToken()
as it is suggested in MapImageLayer | API Reference | ArcGIS API for JavaScript 4.4 and
IdentityManager | API Reference | ArcGIS API for JavaScript 4.4
but i get the error, in console , "esriId.registerToken is not a function". What's wrong?
thank you,
Kostas
var esriRequireModules = [
    "esri/Map",
    "esri/request",
    "esri/geometry/support/webMercatorUtils",
    "esri/geometry/Point",
    "esri/widgets/Search",
    "esri/Graphic",
    "esri/symbols/PictureMarkerSymbol",
    "esri/PopupTemplate",
    "esri/layers/GraphicsLayer",
    "esri/layers/FeatureLayer",
    "esri/layers/MapImageLayer",
    "esri/layers/GroupLayer",
    "dojo/on",
    "dojo/domReady!",
    "esri/identity/IdentityManager"
var esriRequireCallback = function(
    Map,
    esriRequest,
    webMercatorUtils,
    Point,
    Search,
    Graphic,
    PictureMarkerSymbol,
    PopupTemplate,
    GraphicsLayer,
    FeatureLayer,
    MapImageLayer,
    GroupLayer,
    on,
    esriId
esriId.registerToken({
    server : ...
    token : ...
    expires : ...
esriLoader.require(esriRequireModules, esriRequireCallback);
roemhildtg
Your module paths and module variables need to appear in the same order.
    "esri/Map", // 0
    "esri/request", // 1
    "esri/geometry/support/webMercatorUtils", //2
    "esri/geometry/Point", //3
    "esri/widgets/Search",//4
    "esri/Graphic",//5
    "esri/symbols/PictureMarkerSymbol",//6
    "esri/PopupTemplate",//7
    "esri/layers/GraphicsLayer",//8
    "esri/layers/FeatureLayer",//9
    "esri/layers/MapImageLayer",//10
    "esri/layers/GroupLayer",//11
    "dojo/on",//12
    "dojo/domReady!",//13
    "esri/identity/IdentityManager"//14
    Map,//0
    esriRequest,//1
    webMercatorUtils,//2
    Point,//3
    Search,//4
    Graphic,//5
    PictureMarkerSymbol,//6
    PopupTemplate,//7
    GraphicsLayer,//8
    FeatureLayer,//9
    MapImageLayer,//10
    GroupLayer,//11
    on,//12
    esriId‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍//13‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
So in your case, esriId is actually the domReady object. you can switch the two paths in your require array, or add another variable in your callback to fix.
roemhildtg
    "esri/Map", // 0
    "esri/Graphic",//5
    "dojo/on",//12
    Map,//0
    esriRequest,//1
    Point,//3
    Search,//4
    Graphic,//5
    PopupTemplate,//7
    GraphicsLayer,//8
    FeatureLayer,//9
    MapImageLayer,//10
    GroupLayer,//11
    on,//12
