ESRI JS 4.x popup template
2043
11-02-2017 07:56 AM
deleted-user-OlpHy1NoMNug
I have a feature with a date field that I want to include in a popup.  In the AGOL web map you have the ability to customize the date format but not so when using the popupTemplate in the JS.
See here, Road Closures.
Click on a feature then search for street name (S IRVINE ST for example) to see difference.  Any idea how to fix this?  Should I be using an arcade expression to convert?  How is the AGOL map doing it?
Scott
RobertScheitlin__GISP
Scott,
  you can absolutely format date fields in the 4.x PopUpTemplate:
{DATE_FIELD:DateFormat(selector: 'date', fullYear: true)} produces 4/8/2009
https://developers.arcgis.com/javascript/latest/api-reference/esri-PopupTemplate.html#content
Look for "The formatter functions" section.
Scott,
Indeed, you're correct.  Thanks, Robert.
Scott
