3D editor widget not working properly in my 3d data
869
11-13-2020 02:03 AM
AnupamSharma
I want to have  edit functionality to  the attributes in webscene  but i am unable to do so ,i tried applyEdit  method from arcgis api also 3d editor widget but its not working,   kindly please check where i am getting wrong,i had published 3d layer from arcgis pro software and below i am sharing the scene layer associated with  feature layer as well as portal id of webscene, Thank you in advance
SceneLayer:
https://globolive3d.gl3d.in/agserver/rest/services/Hosted/Anupam_Land_Use/SceneServer
FeatureLayer
https://globolive3d.gl3d.in/agserver/rest/services/Hosted/Anupam_Land_Use/FeatureServer
webscene portal ID: 8482745e9d164eb5afb30a2f6cd883b5
Below is my code for 3d editor
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>
      Edit features in 3D with the Editor widget | Sample | ArcGIS API for
      JavaScript 4.17
    </title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.17/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.17/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      .esri-editor .esri-item-list__scroller {
        max-height: 350px;
      #setting {
        padding: 10px;
    </style>
    <script>
      require([
        "esri/layers/FeatureLayer",
        "esri/WebScene",
        "esri/views/SceneView",
        "esri/widgets/Editor"
      ], function (FeatureLayer, WebScene, SceneView, Editor) {
        // Create a map from the referenced webscene item id
        let webscene = new WebScene({
          portalItem: {
        var view = new SceneView({
          container: "viewDiv",
          qualityProfile: "high",
          map: webscene
        view.when(function () {
          view.popup.autoOpenEnabled = false; //disable popups
          // Create the Editor
          var editor = new Editor({
            view: view
          // Add widget to top-right of the view
          view.ui.add(editor, "top-right");
          const satelliteCheckbox = document.getElementById("satellite");
          // change event handler to set the basempa accordingly
          satelliteCheckbox.addEventListener("change", function (event) {
            view.map.basemap = event.target.checked ? "satellite" : "";
          // Add the checkbox to the bottom-right of the view
          view.ui.add("setting", "bottom-right");
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <div id="editorDiv"></div>
    <div id="setting" class="esri-widget">
      <input type="checkbox" id="satellite" /><label for="satellite"
        >Show satellite basemap</label
      ><br />
    </div>
  </body>
</html>
