wrapAround180 does not work well with esri.geometry.Extent
1450
03-17-2011 08:17 PM
mikewebster
I believe all the geometries work well with rendering when panning across the dateline, except for the extent geometry. I attached a snapshot of what I see.
You can also take the example @
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/graphics/graphics_add.html
and apply
wrapAround180:true
to the esri.Map construct
mikewebster
Just a thought . . . a temp and easy solution incase you need your extent to wrap might be to convert it to a polygon.
