Why isn't Popup's Reposition function working?
1398
01-03-2020 11:53 AM
JackFairfield
The Popup's reposition function doesn't do anything in this jsbin example with a viewDiv that has a 500px height.
Here's the relevant code I'm using:
view.popup.watch("visible", function(val) {
   if (val) {
      view.popup.reposition();
Here's the JSbin example.
RobertScheitlin__GISP
Jack,
  To to a more appropriate test of the popups reposition method use this:
      view.watch('stationary', function(){
        if(view.popup.visible){
If you comment out your
      view.popup.watch("visible", function (val) {
        if (val) {
and then pan the map you will see the popup repostion method works as intended.
