Update/Refresh featureLayer when featureLayer heatmap renderer i.e. field, low/High value changed dynamically
2418
01-05-2022 03:55 AM
ShefaliMantri
Hello Team,
We are using ArcGIS javascript API 4.13.
In our project requirement is, ability to dynamically change field and low and high value of the heat map Renderer for the feature layer.
When we change the heat map Renderer (any above settings) then layer is not showing updated view. When we turn 'OFF' and again turn 'ON' the heat map toggle button then it is showing correct view.
Question - When heat map is ON and suppose we change field or Low/High value, then how layer show correct heat map effect on map without layer re-create or toggle heat map (ON/OFF).
We try layer refresh method although its not worked.
UndralBatsukh
Hi there,
We had an issue with the HeatMapRenderer not updating when the renderer's field changed at runtime. This issue was fixed at version 4.16. So versions 4.16 and greater, the renderer should change whenever you update the renderer's field.
Changing maxPixelIntensity/minPixelIntensity values at runtime always worked. I created this simple app for you to showcase that it is working at 4.22: https://codepen.io/U_B_U/pen/eYGjNZG?editors=1000
If you can't still get it to work then can you please provide me with a simple reproducible case?
-Undral
Noah-Sager
Hi @ShefaliMantri, the latest version of the API is 4.22. Which is quite a bit further along than 4.13. This issue may have been fixed at a previous release. Can you test with 4.22?
ShefaliMantri
Thank you Noah,
I tested to API 4.22 although issue still persist.
UndralBatsukh
Hi there,
-Undral
ShefaliMantri
Thank you Undral,
It's working now. Previously without cloning renderer, I am directly trying to overwrite that's why it's not working.
