Undomanager did not remove graphics when undo()
1345
07-15-2013 06:49 AM
AllenHuang
My attempted on using the UndoManager has been unsuccessful for a couple days and I'm stuck.
I did not setup a proxy.
I create a FeatureLayer object in memory with
 var drawingPointLayer = new esri.layers.FeatureLayer(featureCollection, {
  mode: esri.layers.FeatureLayer.MODE_ONDEMAND
 mapApp.map.addLayer(drawingPointLayer);
created UndoManager and button to perfom undo redo actions
 undoManager = new esri.UndoManager({maxOperations:50});
 var undoButton = new dijit.form.ToggleButton({
  showLabel: false,
  iconClass: "dijitEditorIcon dijitEditorIconUndo",
  onClick: function(){
   undoManager.undo();
   checkUndoRedoState();
   mapApp.map.graphics.graphics.splice(mapApp.map.graphics.graphics.length-1, 1);
   mapApp.map.graphics.redraw();
   alert(undoManager.length + " | " + mapApp.map.graphics.graphics.length);
 }, "undoButton");
 var redoButton = new dijit.form.Button({
  showLabel: false,
  iconClass: "dijitEditorIcon dijitEditorIconRedo",
   undoManager.redo();
 }, "redoButton");
and add operation to UndoManager
function addToUndoManager(graphic, task){
 var operation;
 var featureLayer = mapApp.map.getLayer("drawPointLayer");
 //var featureLayer = mapApp.map.getLayer("landuseLayer");
 if(task=="add"){
  featureLayer.applyEdits([graphic], null, null, function() {
            operation = new esri.dijit.editing.Add({
    featureLayer: featureLayer,
    addedGraphic: graphic
 if(operation)
  undoManager.add(operation);
 alert(undoManager.canUndo + " | " + undoManager.canRedo + " | " + operation.label + " | " + operation.type + " | " + undoManager.length + " | " + mapApp.map.graphics.graphics.length);
New point markers would be added to the map via mouse click. Undomananger would register. But when I press the undo button, the graphics on the map would not disappear.
I'm clueless on what to do next to solve this problem.
Please Help
AllenHuang
I figure it out.. finally
what I should have done is use the addedGraphics parameter instead of addedGraphic
 if(task=="add"){
    addedGraphics: [graphic]
I think this is a bug because when I read into the performUndo() code
 alert(undoManager.peekUndo().performUndo) //not performUndo().. This will execute the function and won't display the inline code in alert
the alert shows
 function(){ this._featureLayer.applyEdit(null, null, this._addedGraphics); }
when use addedGraphic: graphic
 alert(undoManager.peekUndo()._addedGraphic);
returns undefined, which means that addedGraphic did not get pushed into _addedGraphics.
