Hi, I have questions about the label of the templates of the Template Picker.
For example, this is the templates and the labels after the Template Picker widget is started up.
But the cartography design of the corresponding layer in the MXD is like the following. In the MXD, the label of the symbol is different from the label of the template picker. See the red-boxed items.
Actually, the symbology of the MXD is based on the field of "Status", which include five different value: Retired, Temporary, Pending, Other, and Current.
I have one guess: since the template picker is based on the feature layer, the label of the template is not based on the symbol label of the MXD file but based on the actual value of the designed field. Is this guess right?
My template picker is based on feature layer. How can I customize the template label instead of using the actual field values?
