suggestion on my source dont work
3307
12-09-2015 05:54 PM
joelde_freitas
hi,
i put 2 sources on the search widget and disabled the default source.
the autosuggestion dont work with my sources.
it work only with the default source.
how can i get it work?
thanks
RobertScheitlin__GISP
Joel,
FYI from the API help docs:
Suggestions are available if working with a 10.3 geocoding service that has suggest capability loaded or a 10.3 feature layer that supports pagination, i.e. supportsPagination = true. Also, if using the Esri locator, suggest does not have an option to return a number of suggestions.
