Sublayers not showing when more than one layer have visible value as true
3271
7
07-11-2019 05:14 AM
bobongubza
Something really strange is happening and I do not know why. When I create a new MapImageLayer and call for two sublayers whereas the visible value for both sublayers is 'true' I get an error.
RAILLAYER = new MapImageLayer({
url: "https://rave1:6443/arcgis/rest/services/RAIL/MapServer", sublayers: [
{id: 0,
visible: true,
title: "Railway Station"},
{id: 20,
visible: true,
title: "Railway"}
When there is one visible value as true (the other false), the sublayer displays.
url: "https://rave1:6443/arcgis/rest/services/RAIL/MapServer", sublayers: [{id: 0,
visible: true,
{id: 20,
visible: false,
title: "Railway"}
The weird thing is that I tried using the sample layer from esri
http://sampleserver6.arcgisonline.com/arcgis/rest/services/911CallsHotspot/MapServer
and it works perfectly when both sublayers visible value are defined as true.
So I just want to figure out what could be the cause of this issue. By the way I am using arcgis javascript 4.10
RobertScheitlin__GISP
Bobo,
  Try adding the sublayers in descending order:
  sublayers: [{
    visible: true,
    title: "Railway"
    visible: true,
bobongubza
Robert, you are an arcgis wiz. Thank you, it worked.
Could you explain to me why it works in descending order but not in ascending order.
Bobo,
  This is just a known feature with sublayers that is not documented. Don't forget to mark the question as answered.
bobongubza
Before I mark as answered, something strange is still happening.
this works perfectly.
{id: 16,
visible: true,
title: "Highway"},
{id: 10,
visible: true,
title: "Sand Dune"},
{id: 8,
visible: true,
title: "Dams"},
{id: 7,
visible: true,
title: "Rivers"},
{id: 5,
visible: true,
title: "DWAF Water Scheme"},
{id: 4,
visible: true,
title: "Prison"},
{id: 3,
visible: true,
title: "School"},
{id: 2,
visible: true,
title: "Police Station"},
{id: 1,
visible: true,
title: "Health Facility"}
But when my code is like this
{id: 11,
visible: true,
title: "Vegetation"},
{id: 10,
visible: true,
{id: 8,
visible: true,
title: "Dams"},
{id: 7,
visible: true,
title: "Rivers"},
{id: 5,
visible: true,
{id: 4,
visible: true,
title: "Prison"},
{id: 3,
visible: true,
title: "School"},
{id: 2,
visible: true,
{id: 1,
visible: true,
The same error i received as last time still occurs. Its kind of selective even if it is in descending order.
Bobo,
   What is layer 11? is it an actual layer or a group layer? Are you sure the id 11 is your Vegetation layer?
bobongubza
It is the actual layer.
Sorry to say this might be a bug then.
