In 4.9, the following code creates a circle with a green dotted line as the outline when the map is clicked. In 4.10, it ignores:
style: "short-dot"
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Intro to ArcGIS API for JavaScript</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<script src="https://js.arcgis.com/4.10/"></script>
</head>
<body>
<div id="viewDiv"></div>
</body>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/symbols/SimpleMarkerSymbol",
"esri/Graphic"
], function (
Map,
MapView,
SimpleMarkerSymbol,
Graphic
var map = new Map({
basemap: "topo"
var view = new MapView({
container: "viewDiv",
map: map,
zoom: 10,
center: [-118, 34],
rotation: 30
const markSymbol = new SimpleMarkerSymbol({
color: "white",
style: "circle",
outline: {
color: [56, 158, 0, 1],
width: 2,
style: "short-dot"
view.on("click", function (event) {
console.log(event)
var symbolGraphic = new Graphic({geometry: event.mapPoint, symbol: markSymbol});
view.graphics.add(symbolGraphic);
</script>
</html><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
