Simple Zoom
2250
7
05-19-2020 11:14 AM
jaykapalczynski
Honored Contributor
Just looking for a simple zoom ...
I don't think I need to query anything....I am adding a feature to a graphics layer....then want to zoom to that Graphics Layer
Thoughts?
    var mapright = new Map({
        basemap: "dark-gray",
        layers: [resultsLayer2, resultsLayer4]
    var viewright = new MapView({
        container: "viewDivright",
        map: mapright
    function displayResultsUniqueID(results) {
        var features2 = results.features.map(function (graphic) {
            graphic.symbol = {
                type: "simple-fill",  // autocasts as new SimpleFillSymbol()
                color: [51, 51, 204, 0.9],
                style: "solid",
                outline: {  // autocasts as new SimpleLineSymbol()
                    color: "white",
                    width: 1
            return graphic;
        window.resultsLayer2.addMany(features2);
        viewright.goTo(features2.Extent);
RobertScheitlin__GISP
Jay,
  Then this is one way. Get the extent of the geometries and that extents center and use that is the target.
var featGeoms = features2.map(function(gra){
  return gra.geometry;
var union = geometryEngine.union(featGeoms);‍‍
var opts = {
   duration: 5000 // Duration of animation will be 5 seconds
viewright.goTo({
    target: union.extent.center,
    zoom: 7
}, opts)
  .catch(function (error) {
  if (error.name !== "AbortError") {
   console.error(error);
jaykapalczynski
Honored Contributor
This is all the code that is relevant I think
    var PolygonsUrl = "https://xxxx/arcgis/rest/services/Test/Poly/FeatureServer/0";
    window.PolygonsLayer = new FeatureLayer({
        url: PolygonsUrl,
        outFields: ["*"],
        visible: true
    window.resultsLayer2 = new GraphicsLayer({
        opacity: .5
        map: mapright
    function queryMultipartPolyongUniqueID4(feature) {
        var str = feature;
        //alert(str);
        var query = "";
        query = window.MultiPartPolygonsLayer.createQuery();
        query.where = "ID = '" + str + "'"; // "1a35172e071f4a33b191172a9b4b02ae";
        return window.PolygonsLayer.queryFeatures(query);
            graphic.symbol = {
                style: "solid",
                    color: "white",
                    width: 1
            return graphic;
Jay,
   Looks like features2 is an array of graphics if that is the case then an array does not have an extent property.
just use:
viewright.goTo(features2);
jaykapalczynski
Honored Contributor
If I want to do something like this how to I define the graphics Layer...this does not seem to work
        viewright.goTo({
            target: features2,
            zoom: 7
        }, opts)
Jay,
   I'm confused. If you are sending an array of graphics then you will normally zoom to the extent of that graphics array. So are you saying that you want to zoom to zoom level seven and that the view centered on the graphics array?
jaykapalczynski
Honored Contributor
Looking to zoom to the graphics layer which works but want to zoom back just a bit....it zooms to the actual geometry but to close for my liking
so maybe an expand?
and use a duration to zoom to those features
var opts = {
viewright.goTo({
    target: features2,
    zoom: 7
}, opts)
Jay,
var opts = {
viewright.goTo({
    zoom: 7
}, opts)
jaykapalczynski
Honored Contributor
Thanks once again .... didnt know I had to grab the geometries first....CHEERS
