Separating points that overlap in a zoomed out world view
618
09-16-2020 07:01 AM
JamesMaikranz
Using the ArcGIS API, I have built a web page with a base map which displays custom data through picture-marker graphic points. Some of these points are on the same geolocation and I need to view them separated. I cannot use 3D due to the constraints of the systems I use. Is there a way to separate points in a global view when those points share the same latitude and longitude? Or even when those points are close together and overlap in a zoomed out world view.
