Query and QueryTask Not Returning Results ... Error In Syntax?
4120
14
10-03-2018 10:31 AM
JohnRichardson
var layerURL = "http://172.20.25.165:6080/arcgis/rest/services/Crime2018/FeatureServer/";            //querys the crimes layer for all burglaries
      var burgresultsLayer = new GraphicsLayer();
            var burgQsym = {                                       //creates the symbol for burglaries query
            type: "simple-marker",
            color: "green",
            style: "triangle",
      /*alert(layerURL);*/
      var qTask = new QueryTask({url : layerURL});
      var burgQuery = new Query();
      burgQuery.returnGeometry = true;
      var fieldBoys = burgQuery.outFields = ["Offense", "Location"];
      /*alert(fieldBoys);*/
      burgQuery.where = "Offense = Burglary";
      qTask.execute(burgQuery).then(function(results) {
            console.log(results.features);
      qTask.executeForCount(burgQuery).then(function(results) {
            console.log(results);
JohnRichardson
require([
      "esri/Map",
      "esri/views/MapView",
      //"esri/views/SceneView",
      "esri/widgets/Home",
      "esri/widgets/Search",
      "esri/widgets/BasemapGallery",          //loading the necessary libraries and classes and objects from the ESRI API
      "esri/widgets/Expand",
      "esri/layers/FeatureLayer",
      "esri/layers/ImageryLayer",
      "esri/widgets/LayerList",
      "esri/tasks/QueryTask",
      "esri/tasks/support/Query",
      "esri/layers/GraphicsLayer",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
      ],function(Map, MapView, Home, Search, BasemapGallery, Expand, FeatureLayer, ImageryLayer, LayerList, GraphicsLayer, QueryTask, Query) {
      var map = new Map({     //creates new empy map, with streets as basemap
      basemap: "streets"
      var view = new MapView({      //creates the map view and shows the map in the mapBox container
      container: "mapBox",
      map: map,
      zoom: 13,
      center: [-85.675, 40.09],      //centers map on Anderson, Indiana
      var homewidget = new Home({     //adds the home widget to the map view
      view: view
      view.ui.add(homewidget, "top-left");
      searchWidget = new Search({     //add the search widget to the map view
      view:view,
      showInfoWindowOnSelect: false,
      popupEnabled: false,
      popupOpenOnSelect: false
      view.ui.add(searchWidget, "bottom-right");
      var basemapGallery = new BasemapGallery({     //add the basemap gallery widget to map view
      view: view
      var bgExpand = new Expand({     //puts the basemap gallery widget into an expand widget
      view: view,
      content: basemapGallery,
      collapseTooltip: "Close Basemap Gallery",
      expandTooltip: "Open Basemap Gallery"
      view.ui.add(bgExpand, "bottom-left");
      var burgSym = {                                   //creates the symbol for burglaries
           color: "blue",
           style: "diamond",
      var theftSym = {                                   //creates the symbol for thefts
           color: "red",
           style: "square",
      var otherSym = {                                   //creates a default symbol
           color: "black",
           style: "circle"
      var crimeRenderer = {                              //creates the renderer for the crimes layer
           type: "unique-value",
           defaultSymbol : otherSym,
           field: "Offense",
           uniqueValueInfos: [{
                value: "Burglary",
                symbol: burgSym
                value: "Theft",
                symbol: theftSym
      var featurelayer = new FeatureLayer({      //adds a feature layer of 2018 Crime
      url: "http://172.20.25.165:6080/arcgis/rest/services/Crime2018/FeatureServer",
      title: "2018 Crime",
      renderer: crimeRenderer,
      visible: false
      map.add(featurelayer, 2);
      var orthLayer = new ImageryLayer({      //adds an image layer of Orthos SCE
      url: "http://172.20.25.165:6080/arcgis/rest/services/Ortho_SCE/ImageServer",
      title: "Ortho - East",
      visible: false
      map.add(orthLayer, 0);
      var orthLayer2 = new ImageryLayer({      //adds an image layer of Orthos SCW
      url: "http://172.20.25.165:6080/arcgis/rest/services/Ortho_SCW/ImageServer",
      title: "Ortho - West",
      visible: false
      map.add(orthLayer2, 1);
      var layerList = new LayerList({     // add a layer list to the map view
      view: view
      var llExpand = new Expand({     //puts the layer list widget into an expand widget
      view: view,
      content: layerList,
      collapseTooltip: "Close Layer List",
      expandTooltip: "Open Layer List"
      view.ui.add(llExpand, "top-right");
      var layerURL = "http://172.20.25.165:6080/arcgis/rest/services/Crime2018/FeatureServer/0";
            color: "green",
            style: "triangle",
      burgQuery.where = "Offense = 'Burglary'";
      qTask.execute(burgQuery).then(function(results) {                                   //queries the crimes layer for all burglaries (not)
RobertScheitlin__GISP
John,
  That is definitely your issue.
require([
      "esri/Map",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
      ],function(
      LayerList, QueryTask, Query, GraphicsLayer, dom, on) {
Here is your order fixed
JohnRichardson
Robert .... yes!
Thank you so much!
I guess I did not realize the order of the requires and in the function call were important!
JohnRichardson
So the order of the requires has to match the order in the function ... but not the order that they are used in the script itself necessarily?
Correct.
