Problem displaying attribute table via actions & LayerList
1042
09-05-2021 12:07 PM
Amadeus111
I am trying to open an attribute table but I get something else :
It tries to create an infinite number of tables. Do you have any idea why that happens?
Code:
        let layerList = new LayerList({
            view: view,
            container:"sideDiv",
            listItemCreatedFunction: defineActions
        function defineActions(event) {
        // The event object contains an item property.
        // is is a ListItem referencing the associated layer
        // and other properties. You can control the visibility of the
        // item, its title, and actions using this object.
          var item = event.item;
          item.actionsSections = [
                title: "Go to full extent",
                className: "esri-icon-zoom-out-fixed",
                title: "Attribute Table",
                className: "esri-icon-table",
                title: "Layer information",
                className: "esri-icon-description",
          view.when(function() {
              layerList.on("trigger-action", function(event) {
              // The layer visible in the view at the time of the trigger.
              // Capture the action id.
              var id = event.action.id;
              activeLayer = event.item.layer
              if (id === "full-extent") {
                // If the full-extent action is triggered then navigate
                // to the full extent of the visible layer.
                view.goTo(activeLayer.fullExtent);
              } else if (id === "attribute-table") {
                // If the table action is triggered, then
                // open the attribute table
                var featureTable = new FeatureTable({
                  view: view, // make sure to pass in view in order for selection to work
                  layer: activeLayer,
                  container: "tableDiv"
              } else if (id === "information") {
                // If the information action is triggered, then
                // open the item details page of the service layer.
                window.open(activeLayer.url);
    </script>
