The message you are trying to access is permanently deleted.
Hi guys,
I have layer which has one field "Images" and in this field i have image links from my shared folder (e.g. K:\images\image_1.jpg).
How can i open this image in popup or in other window? I tried use <img src='{Images}'>, also make DIV in popupTemplate to have clickable content , but have no success.
Any ideas and help please/
Thank you in advance
I wonder if you already tried the steps described on this article: How To: Add an image at the top of pop-up windows in ArcGIS Online
Hi, not sure what you mean but are you referring to using it as a link?
<a href="http link to your image" target="_blank">Image</a>Just note that if you want to share that image, it needs to be hosted on a web server so that it can be accessed via http/https
