No Map Shows If I Modify the Basemap on Esri-React-Boot
2604
01-29-2021 01:28 PM
developerarce
I am pretty stuck and do not know what I am doing wrong. I am currently just trying to modify this library from Esri (https://github.com/Esri/esri-react-boot).
It uses OAuth, but you can view the map without having to sign in. However, if I want to modify the basemap config to show arcgis-topographic like the tutorial shows here (https://developers.arcgis.com/javascript/latest/display-a-map/), I do not get any render of the map.
The tutorial uses an API Key, but when using OAuth, you shouldn't need to do anything like that.
Below are the only 2 files I have modified, everything else is the same as in the repo.
config.json
  "appVersion": "2.0.0",
  "apiUrl": "api",
  "loginUrl": "api/auth/arcgis",
  "logoutUrl": "api/logout",
  "jsapiUrl": "https://js.arcgis.com/4.17/",
  "jsapiV4": true,
  "clientId": "<hidden>",
  "sessionId": "esri-react-boot_session",
  "mapConfig": {
    "basemap": "arcgis-topographic",
    "center": [-118.805, 34.027],
    "zoom": 13
package.json
  "name": "react-jsapi-app",
  "version": "0.1.0",
  "private": true,
  "homepage": "/",
  "dependencies": {
    "@esri/arcgis-rest-auth": "^3.0.0",
    "@esri/arcgis-rest-portal": "^3.0.0",
    "@esri/arcgis-rest-request": "^3.0.0",
    "calcite-react": "^0.44.0",
    "esri-loader": "^2.16.0",
    "framer-motion": "^1.6.18",
    "js-cookie": "^2.2.1",
    "react": "^16.12.0",
    "react-dom": "^16.12.0",
    "react-redux": "^7.1.3",
    "react-router-dom": "^5.1.2",
    "react-transition-group": "^4.3.0",
    "redux": "^4.0.4",
    "redux-saga": "^1.1.3",
    "styled-components": "^4.4.1"
  "scripts": {
    "start": "react-scripts start",
    "build": "react-scripts build",
    "test": "react-scripts test --env=jsdom",
    "eject": "react-scripts eject"
  "devDependencies": {
    "react-scripts": "^3.3.0"
  "browserslist": {
    "development": [
      "last 2 chrome versions",
      "last 2 firefox versions",
      "last 2 edge versions"
Thank you in advance.
Tags (3)
by Anonymous User
Not applicable
It looks like there are tiers of what maps are available and 'arcgis-topographic' falls under needing an API key
BaseMap availability
'topo' is available for use without an API key, but requires a valid ArcGIS Online organizational subscription or an ArcGIS Enterprise license.  Maybe try using that one?
by Anonymous User
Not applicable
developerarce
Thank you very much.
coryeicher
I'm actually trying to get an ArcGIS JS + React application to work _with_ an ArcGIS Developer API key (https://developers.arcgis.com/javascript/latest/api-reference/esri-config.html#apiKey)
In vanilla JS it is done like this:
    require(["esri/config"],
      function (esriConfig) {
      esriConfig.apiKey = "YOUR_KEY_HERE";
Has anyone cracked this nut?
CORY EICHER
www.eichcorp.com
[email protected]
coryeicher
I was able to make this work using '@arcgis/core/config'
import config from '@arcgis/core/config';
export const webmap = new WebMap({
	portalItem: {
		id: 'abc123' // portal id of your webmap
config.apiKey = 'YOUR_KEY';
 For example you can add the import after this line...
https://github.com/odoe/jsapi-esm-react/blob/main/src/data/webmap.js#L3
... replace this webmap with your new WebMap here...
https://github.com/odoe/jsapi-esm-react/blob/main/src/data/webmap.js#L17
... and set apiKey after this line...
https://github.com/odoe/jsapi-esm-react/blob/main/src/data/webmap.js#L33
CORY EICHER
www.eichcorp.com
[email protected]
