Mapserver not found
5579
13
12-11-2018 06:57 AM
EbunoluwaAkingbaso
After installing JavaScript API and SDK , i tried to test my  installation but it throws the error - MapServer not found. Actually arcgis/rest/services/Folder/Custom_Base_Map/MapServer was not found. I don't know if i have done something wrong. Please what could be the solution to this error. Thanks
RobertScheitlin__GISP
Please share the code you are attempting to use.
EbunoluwaAkingbaso
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>Test Map</title>
<link rel="stylesheet" href="https://eif-gis-serv.eifer.kit.edu/arcgis_js_api/library/4.9/dijit/themes/claro/claro.css" />
<link rel="stylesheet" href="https://eif-gis-serv.eifer.kit.edu/arcgis_js_api/library/4.9/esri/css/main.css" />
<style>
html,
body,
#viewDiv {
margin: 0;
padding: 0;
width: 100%;
height: 100%;
</style>
<script src="https://eif-gis-serv.eifer.kit.edu/arcgis_js_api/library/4.9/dojo/dojo.js"></script>
<script>
var myMap, view;
require([
"esri/Basemap",
"esri/layers/TileLayer",
"esri/Map",
"esri/views/MapView",
"dojo/domReady!"
], function (Basemap, TileLayer, Map, MapView){
// If you do not have public Internet access then use the Basemap class
// and point this URL to your own locally accessible cached service.
// Otherwise you can just use one of the named hosted ArcGIS services.
// https://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer
var layer = new TileLayer({
url: "https://eif-gis-serv.eifer.kit.edu/arcgis/rest/services/Folder/Custom_Base_Map/MapServer"
var customBasemap = new Basemap({
baseLayers: [layer],
title: "Custom Basemap",
myMap = new Map({
basemap: customBasemap
view = new MapView({
center: [-111.87, 40.57], // long, lat
container: "viewDiv",
map: myMap,
zoom: 6
</script>
</head>
<body class="claro">
<div id="viewDiv"></div>
</body>
</html>
Ebunoluwa,
  So this code:
assumes that you have an ArcGIS Server instance setup on the eif-gis-serv.eifer.kit.edu server. Is that the case?
EbunoluwaAkingbaso
Yep that is the case
So when you enter
in your browsers address bar do you get the rest service end point page?
EbunoluwaAkingbaso
No, I get this:
So that means you do not have your web adaptor setup completely/correctly.
Does it work if you bypass the web adaptor
https://eif-gis-serv.eifer.kit.edu:6443/arcgis/rest/services/Folder/Custom_Base_Map/MapServer
EbunoluwaAkingbaso
No it does not work if i bypass the web adaptor
It responded connection insecure.
Try changing :6443 to :6080 in the url above and try again.
