Leaflet- DynamicMapLayer popup help
5727
03-01-2016 11:18 AM
BillChappell
I'm trying to make a simple leaflet map with a popup but I'm having trouble with the field name in the popup.
Following the example Custom Popup with Dynamic Map Layer | Esri Leaflet  you can see the popup is based on featureCollection.features[0].properties.FIELDNAME, my issue is my data is in SDE and I get this:
DOHGIS.NYSDOH_CI_DATA.NAME ( type: esriFieldTypeString , alias: Facility Name , length: 250 )
featureCollection.features[0].properties.DOHGIS.NYSDOH_CI_DATA.NAME  doesn't work because of the periods in the name.
featureCollection.features[0].properties.NAME  doesn't work..
If I use the alias I get
featureCollection.features[0].properties."Facility Name" this doesn't work because of the quotes and space.
var temp = "Facility Name"
featureCollection.features[0].properties.temp; also fails.
Of course fieldnames with an underscore instead of a space work.
Beyond adding new fields to fix the database any ideas?
Bill
BillChappell
featureCollection.features[0].properties["Facility Name"];
Got It...   I removed the period after the properties and encased my quotes within brackets.
BillChappell
SteveOchieng
Hi Bill,
I am experiencing this problem and I have tried the solution you are suggesting here but it can't seem to work for me. Did you find something else along this line that can help me
I have put mine this way featureCollection.features[0].properties['PLOTNO_1'] I have also tried " " but I still get undefined.
Assit please!
BillChappell
Sorry i was never notified of your question, did you ever figure this out?
I know upper/lower case makes a difference, and in GeoJSON without SDE it's features[0].properties.FIELDNAME
