is it possible for the Sketch UI widget, that it only shows the sketch point button?
1818
03-08-2019 05:18 AM
WwLl
Hey,
i want only the Point Button, can i somehow turn off the other function?
thanks!
RobertScheitlin__GISP
Just add this css rule to your code:
  .esri-sketch__button.esri-icon-polyline,
    .esri-sketch__button.esri-icon-polygon,
    .esri-sketch__button.esri-icon-checkbox-unchecked,
    .esri-sketch__button.esri-icon-radio-unchecked {
      display:none;
WwLl
Thanks, it worked
JonathanUihlein
We will be adding a property to control the display of specific tools in an upcoming release (4.12). In the meantime, you can use Robert's solution.
GregoryBologna
add what you want
          var sketch = new Sketch({
            layer: somelayer
            view: view,
            availableCreateTools: ["polyline""polygon""rectangle""circle"]
