In arcgis 4.13, it is not returning all attributes for a feature layer if we check the graphic.attributes of the layer. how can we able to load all attributes
1850
12-04-2019 03:24 AM
reneeshtk
I am using a esri-react package and when I tried to access layer field values from graphic.attributes objects, it shows only two fields in it. objectid and the display field. in 4.10 there was all attributes. how can I get all attributes loaded?
Tags (1)
RobertScheitlin__GISP
Reneesh,
   Sounds like you have not set the layer outFields property in the constructor then.
Set this property to include the fields that will be used for client-side queries if the fields are not part of required fields used for rendering.
Reneesh,
reneeshtk
you are correct, when I added the outfields it worked.
map.allLayers.forEach(layer => {
if(layer.type == 'feature') {
layer.outFields = ['*'];
