Image does not display in infotemplate
2065
6
06-08-2020 10:43 PM
FaryalSafdar
I have added image in attribute table. It looks like this:
Now I want to display this image into infotemplate.
so far I am doing like this:
var content = "<b>Name</b>: ${name}" +                            "<br><b>Picture</b>: ${Pic}" +                  "<br><b>Last Name</b>: ${lname}" ;    var infoTemplate = new InfoTemplate("${FIELD_NAME}", content);
But it does not display image. It is empty. image is showing in identity window in ArcGis. but not in infotemplate
Noah-Sager
What version of the JS API are you using? If 4x, here is a really nice sample that shows how to use various elements in a popup: Multiple popup elements | ArcGIS API for JavaScript 4.15
FaryalSafdar
i am using 3.20 version.
FaryalSafdar
how we display image in info template from attribute table of the feature layer?
Noah-Sager
This sample shows how to use the InfoWindowBase class to create a custom info window.
Custom info window | ArcGIS API for JavaScript 3.32
This sample shows how to format the content of an info window using formatting functions.
Format info window content | ArcGIS API for JavaScript 3.32
This sample creates and use a popup template that references fields from a relationship.
Popup with related fields | ArcGIS API for JavaScript 3.32
FaryalSafdar
thanks for your reply . but it seems nobody understand my problem. all these examples shows manual adding of images in infotemplate. my problem is this i have to add image in attribute table then show that image in infotemplate along with attributes of the feature layer
RobertScheitlin__GISP
