I want to merge two graphics into one.
1902
01-10-2019 10:00 AM
EugeneStaten
I have two circles.  The inner circle is red and represents a tightly controlled buffer around a point.  The outer circle is yellow and represents a larger buffer where conditions are not as dire.
I want to combine the two circles, maintaining their individual symbologies, into one graphics that can be turned into a json object and stored in a user database.
Later, I want to pull this data into a map by using:
                   var dangerGraphic = new Graphic(json);
                   layer.add(dangerGraphic);
This would make the object similar to AutoCad blocks or Microstation Cells.
I know I can store the two circles as an array of graphics, but I am curious if there is a service that would do this.
RobertScheitlin__GISP
Eugene,
  One graphic can not have two different symbologies. So you would have to maintain two graphics. You can use toJson method of Circle
https://developers.arcgis.com/javascript/3/jsapi/circle-amd.html#tojson  or Polygon
https://developers.arcgis.com/javascript/3/jsapi/polygon-amd.html#tojson  to get the json for the geometry.
Eugene,
EugeneStaten
OK,  Thanks Robert!!!
It's as I thought...
Perhaps ESRI will consider this for future releases.
