I am trrying to call WMS layer from Geoserver using Arcgis API for JS
1234
02-05-2021 01:23 AM
ratneshsharma
HI
I am trying to call WMSlayer from Geoserver using Arcgis API for JS
But the layer not opening in web browser
Please rectify the code and share
thanks with regards
Ratnesh Sharma
CODE_SAMPLE
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>WMSLayer | Sample | ArcGIS API for JavaScript 4.16</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="/arcgis_js_api/library/4.14/esri/css/main.css">
<script src="/arcgis_js_api/library/4.14/init.js"></script>
<script>
require(["esri/Map",
"esri/views/SceneView", "esri/widgets/LayerList", "esri/layers/WMSLayer"],
function (Map, SceneView, LayerList, WMSLayer)
var layer = new WMSLayer({
url: "http://localhost:8181/geoserver/sf/wms",
sublayers: [
var map = new Map({
basemap: {
baseLayers: [layer]
var view = new SceneView({
container: "viewDiv",
map: map
view.when(function() {
var layerList = new LayerList({
view: view
// Add widget to the top right corner of the view
view.ui.add(layerList, "top-right");
</script>
</head>
<body class="calcite">
<div id="viewDiv"></div>
</body>
</html>
