How to get view.goTo to loop through multiple graphics...
2157
08-03-2022 09:32 AM
Lake_Country_GIS
Hi there...
I'm trying to animate through a set of graphics from a featurelayer. For some reason my code only zooms to the last feature (or, just zooms through all of them so fast it gets to the end).
Here is the code I am using:
view.whenLayerView(featureLayer).then(function(layerView)
   layerView.watch("updating", function(value)
      if (!value)
         // wait for the layer view to finish updating
         if (loading != "done")
            // query all the features available for drawing.
            layerView
               .queryFeatures(
                  geometry: featureLayer.extent,
                  returnGeometry: true
               .then(function(results)
                  graphics = results.features;
                  graphics.forEach(function(result, index)
                     lat = result.geometry.latitude;
                     lon = result.geometry.longitude;
                     view.goTo(
                        center: [lon, lat],
                        zoom: 4
                        duration: 30000,
                        maxDuration: 30000,
                  loading = "done";
               .catch(function(error)
                  console.error("query failed: ", error);
I would like the application to zoom to one graphic, wait 2 seconds, then pan over to the next graphic and so on.
Thanks in advance,
M
Tags (3)
2 Solutions
JoelBennett
MVP Regular Contributor
Perhaps something like the following:
function stepThroughGraphics(view, graphics, index) {
	if (index < graphics.length) {
		var geometry = graphics[index++].geometry;
		view.goTo({
			center: [geometry.longitude, geometry.latitude],
			zoom: 4
			duration: 30000,
			maxDuration: 30000
		}).then(function() {
			window.setTimeout(stepThroughGraphics.bind(view, graphics, index), 2000);
	} else
		loading = "done";
//etc
view.whenLayerView(featureLayer).then(function(layerView) {
	layerView.watch("updating", function(value) {
		if (!value) {
			if (loading != "done") {
				layerView.queryFeatures({
				}).then(function(results) {
					stepThroughGraphics(view, results.features, 0);
				}).catch(function(error) {
JoelBennett
One thing I see is that the line with window.setTimeout should instead be:
window.setTimeout(stepThroughGraphics.bind(window, view, graphics, index), 2000);
(forgot about that first argument in the call to bind...)
JoelBennett
		view.goTo({
			zoom: 4
			duration: 30000,
			maxDuration: 30000
	} else
		loading = "done";
//etc
		if (!value) {
Lake_Country_GIS
Thanks. That looks like a good approach...
Seems it zooms to the first feature, then errors out though:
Not sure why. Will debug a bit.
Cheers.
JoelBennett
