How to create a popup
2994
12-12-2021 08:22 PM
altair
Hi everyone, I am new here. I am wondering on how  to create a popup like when the user clicked the pin. it will look like this, I used graphic to the map using PictureMarkerSymbol
     const point = new Graphic({
        geometry: {
          latitude: 95.7129,
          longitude:37.0902,
          type: 'point',
        symbol: LocationPin,
        popupTemplate: {
          title:"",
          actionsMenuEnabled: false,
          content: [{
            type: "text",
            text: "<br><div class=\"popuptemplate\"><u>" + teacher.name + "</u> <br>" +
             "<div class=\"body2\">" + location.address.street1 + ", " + location.address.street2 + "<br>" +
             location.address.city + ", " + location.address.state + " " + location.address.zipCode + "</div></div>"
Tags (1)
Kishore
hi @altair , I assume you are adding the graphic to the map using PictureMarkerSymbol you can use attributes and popup template while creating the graphics to display the popup on click. please refer the code below:
var pointGraphic = new Graphic({
                                            geometry: pointGeometry,
                                            symbol: PictureMarkerSymbol,
                                            attributes: {"ID":"0", "Name":"xxx"},
                                            popupTemplate: {
                                                title: "Name",
                                                content: "you can define any object here..."
Please check the samples & help document at: popup-customcontent
Regards,
Kishore
altair
@Kishore hello, thank you for the response, yes i can display the popup, but i want change the behavior on how the popup display, i just want to display the popup just like in the picture
Kishore
@altair  Hi,
If you are using ESRI popup widget from 4.x, the default CSS details are available at "Popup.scss". you can alter the CSS class locally to overwrite the defaults.
Please share your environment details to understand the requirement.
Regards,
Kishore
altair
@Kishore hello,
Yes I am using the ESRI popup, can you please help me on configuring this ?
