How to change feature layer style using its parameters
8591
15
11-19-2016 10:55 AM
SabbiuShah
This is the code that I have written till now.
require([
   "esri/Map",
   "esri/views/MapView",
   "esri/layers/MapImageLayer",
   "esri/renderers/SimpleRenderer",
   "esri/symbols/SimpleFillSymbol",
   "dojo/domReady!"
function(
   Map, MapView, MapImageLayer, SimpleRenderer, SimpleFillSymbol
   var permitsLyr = new MapImageLayer({
   url: "http://apps.geoportal.icimod.org/ArcGIS/rest/services/Nepal/District/MapServer",
   sublayers: [
      visible: true,
      visible: true,
* Add the layer to a map
var map = new Map({
   // basemap: "dark-gray",
   layers: [permitsLyr]
var view = new MapView({
   container: "viewDiv",
   map: map
* Animate to the layer's full extent when the layer loads.
permitsLyr.then(function() {
   view.goTo(permitsLyr.fullExtent);
Now, I would like to change default renderer given in the District - Nepal/District  as
Drawing Info:
      Renderer:
        Simple Renderer:
        Symbol:
                        Simple Fill Symbol:
          Style: esriSFSSolid, Color: [Undefined]
          Outline:
                                    Simple Line Symbol:
            Style: esriSLSSolid, Color: [78, 78, 78, 255], Width: 1
        Label:
        Description:
        Transparency: 0
        Labeling Info: N/A
    How do I change the default color and style for it? Also, using its attribute "DIST_CODE", I also want to apply different color for different polygons.
    I am new to this field. So, help me out.
    SarojThapa1
    Use UniqueValueRenderer in a very similar way. This sample should help you.
    Unique Value Renderer
    SarojThapa1
    Sabbiu,
    Try this code. Why are you using MapImageLayer instead of FeatureLayer?
    permitsLyr.setRenderer(new SimpleRenderer(new SimpleLineSymbol(
                            SimpleLineSymbol.STYLE_SOLID,
                            new Color([(0,128,0, 1]),
                             3)
    SabbiuShah
    Actually, I am new to this field. I found few examples on MapImageLayer. Hence, I went with that.
    Also, I am trying to make a "Density Map Chart" with my own data, but taking the region information from above url. Will you please guide me to the right direction?
    SarojThapa1
    Try the above codes in your MapImageLayer and see if the colors change or not.
    SabbiuShah
    it says, setRenderer is not defined..
    Here's my code.. GitHub - sabbiu/nepal_map
    SabbiuShah
    With few modifications, I am now able to add color. Thanks
    Now I have a question that, "Using different attribute values from the mentioned MapServer, how do I put different color for different regions?"
    SarojThapa1
    SabbiuShah
    Thanks! I'll look into it. Now, I would like to know about, "How can I tweak labeling information?"
    In the mapserver, it is given as,
        Labeling Info:
          Label Placement: esriServerPolygonPlacementAlwaysHorizontal
          Label Expression: [DIST_NAME]
          Use Coded Values: True
          Symbol:
                               Simple Text Symbol:
            Type: esriTS
            Color:0, 0, 0, 255
            Background Color: null
            Border Line Color: null
            Vertical Alignment: bottom
            Horizontal Alignment: center
            Right To Left: False
            Angle: 0
            XOffset: 0
            YOffset: 0
            Font Family: Arial
            Font Size: 8
            Font Style: normal
            Font Weight: bold
            Font Decoration: none
            Min. Scale: 0
          Max. Scale: 0
      For now I'm not even able to show the labels.
      I tried this. But, it didn't work.
      var featureLayer = new FeatureLayer({
         renderer: new SimpleRenderer({
            symbol: new SimpleFillSymbol({
               style: SimpleFillSymbol.STYLE_SOLID,
               color: new Color([0,128,0, 0.5]),
               outline: new SimpleLineSymbol({
                  style: SimpleLineSymbol.STYLE_SOLID,
                  color: new Color([128,0,0,1]),
                  width: 2
         labelsVisible: true,
         labelingInfo: [{
            labelExpression: "[DIST_NAME]",
            labelPlacement: "always-horizontal",
            symbol: new TextSymbol({
               color: [255, 255, 255, 0.7],
               // haloColor: [0, 0, 0, 0.7],
               // haloSize: 1,
               font: {
            minScale: 9250000,
            maxScale: 2400000
         opacity: 1,
         visible: true,
         layerId: 1,
      When I try working with this,
      It shows me error as,
      "SceneView.js:1671 Uncaught (in promise) TypeError: f.labelClass.getLabelExpression is not a function(…)"
      How do I solve this?
      SabbiuShah
      Everything worked till now.
      Now I would like to know, "What do I need to see for showing the name of the district (which is stored in one attribute in the given MapServer) above the district region?
      FC_Basson
      You should post your new question under a new topic.  For labelling have a look at LabelLayer | API Reference | ArcGIS API for JavaScript 3.18
