How to add Clear Prints button in Print widget 4.13
1915
11-16-2019 10:50 PM
ImtiyazPasha
I am trying to add "Clear or delete" button beside every print item and also one "Clear Prints" button at the end to clear all prints in Print widget 4.13 of below sample code, please help me.
Print widget | ArcGIS API for JavaScript 4.13
RobertScheitlin__GISP
Imtiyaz,
   Here is a sample for that:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>Print widget - 4.13</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.13/esri/themes/light/main.css"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
    </style>
    <script src="https://js.arcgis.com/4.13/"></script>
    <script>
      require([
        "esri/views/MapView",
        "esri/widgets/Print",
        "esri/WebMap"
      ], function(MapView, Print, WebMap) {
        var webmap = new WebMap({
          portalItem: {
            // autocasts as new PortalItem()
        var view = new MapView({
          container: "viewDiv",
          map: webmap
        view.when(function() {
          var print = new Print({
            view: view,
            // specify your own print service
            printServiceUrl:
              "https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
          // Add widget to the top right corner of the view
          view.ui.add(print, "top-right");
          print.viewModel.watch('state', function(state){
            if(state === 'ready'){
              setTimeout(() => {
                var button = document.createElement('button');
                button.setAttribute('ID', 'btnClearPrints');
                button.innerText = 'Clear Prints...';
                button.className = 'esri-button';
                button.addEventListener('click', clearPrints);
                var pc = document.getElementsByClassName('esri-print__container')[0]
                pc.appendChild(button);
              }, 500);
          function clearPrints(){
            var prints = document.getElementsByClassName('esri-print__exported-file')
            while (prints.length > 0) prints[0].remove();
    </script>
  </head>
  <body class="calcite">
    <div id="viewDiv"></div>
  </body>
</html>
Imtiyaz,
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
    </style>
    <script>
      require([
        "esri/WebMap"
          portalItem: {
          map: webmap
            view: view,
            printServiceUrl:
              setTimeout(() => {
              }, 500);
    </script>
  </head>
  </body>
</html>
ImtiyazPasha
Thanks a lot.
