How to access data in array after Promise
5029
11-22-2022 08:03 AM
JohnRitsko1
I tried to revive this thread below but to no luck.  Rene has helped me quite a bit but I'm stuck getting values out of a promise statement that puts values into an array.
Previous Post: https://community.esri.com/t5/arcgis-api-for-javascript-questions/executing-a-series-of-queries-insi...
My code hits the swiftly API to get a list of closed bus stops.  This list of stops does not include a lat / lon value so what I do is then query the closedStop Feature class using the bus stop ID from the API in order t join these two results together.  I then have an array "RESULTS" but can't get into the promise.  I can see the values (see attached image array.png).  Just not sure how to get those out of the array.
Input is greatly appreciated.
    BTNelement.addEventListener('click', function(evt){
      view.graphics.removeAll(); // Clears all graphics before placing new updated ones onto the view
        var settings = {
          "url": 'https://api.goswift.ly/',
          "method": "GET",
          "timeout": 0,
          "headers": {
            "Authorization": "",
            "Content-Type": "application/json"
        $.ajax(settings).done(function (response) {
          console.log("Number of Closed Stops: " + response.adjustments.length);
          loadData(response);
          async function loadData(response) {
            var i = 0;
            const queryPromises = response.adjustments.map((data) => {
              // parse data for query
              const query = new Query();
              var queryValue = "Id = " + data.details.stopIds;
              query.where =  queryValue;
              query.outFields = ["*"];
              query.returnGeometry = false;
              apiStopNumber = data.details.stopIds;
              routeAffected = data.details.routesAffected;
              notes = data.notes;
              reason = data.reason;
              i++;
              return [ClosedBusStops.queryFeatures(query), routeAffected, notes, reason, apiStopNumber];
            const resultsArray = await Promise.allSettled(queryPromises);
            // you now have an array of arrays for results, you can flatten them
            const results = resultsArray.flat();
            // now you can create the graphics from the results
            //console.log(results);
            doStuff(results);
    function doStuff(results){
Tags (3)
JohnRitsko1
SOLUTION:
        //console.log("Number of Closed Stops: " + response.adjustments.length);
        loadData(response);
          var xValue = 0;
          var yValue = 0;
          const queryPromises = response.adjustments.map((response) => {
            const apiStopNumber = response.details.stopIds;
            const routeAffected = response.details.routesAffected;
            const notes = response.notes;
            const reason = response.reason;
            var pictureSymbol = {
              type: "picture-marker",
              url:"img/closedStop.jpg",
              height: 20,
              width: 20
            let query = ClosedBusStops.createQuery();
            query.where =  "Id = " + apiStopNumber;
            query.outFields = ["Xcoord, Ycoord"];
              .then(function(queryResponse) {
                if (queryResponse.features.length !== 0) {
                  xValue = queryResponse.features[0].attributes.Xcoord;
                  yValue = queryResponse.features[0].attributes.Ycoord;
                  const busStop = new Point({
                    type: "point",
                    longitude: xValue,
                    latitude: yValue,
                    wkid: 4326
                  popupClosedBusStops = {
                    title: "Bus Stop: " + apiStopNumber,
                    content:"<b>Route(s) Impacted: </b>" + routeAffected + "<br/>" +
                      "<b>Notes: </b>" + notes + "<br/>" +
                      "<b>Reason: </b>" + reason
                  const busStopGraphic = new Graphic ({
                              geometry: busStop,
                              symbol: pictureSymbol,
                              popupTemplate: popupClosedBusStops
                  view.graphics.add(busStopGraphic);
                else{
                  //console.log("Inactive Stop")
        }; // End of async function loadData
      }); // End of Ajax Call
JohnRitsko1
Please see the Issue.png file.  Perhaps I'm going about this wrong.  My issue is accessing the lat/lon within the results I get back.  I can get say the Bus Stop number using results[0].value[1].  However, it's when I try to get values from within the ResultsPromise that I can't seem to figure out.  The Issue.png shows the lat/lon but I can't put together how to get that data, i.e.  results[0].[0].PromiseResults.features[0].attributes.Xcoord and subsequently results[0].[0].PromiseResults.features[0].attributes.Ycoord.
JohnRitsko1
Still hoping someone can chime in on how to get the variables in the issue.png file I show above.  The values in the Promise I'm not sure how to access.   Thank you.
JohnRitsko1
SOLUTION:
        loadData(response);
          var xValue = 0;
          var yValue = 0;
              height: 20,
              width: 20
                    type: "point",
                    longitude: xValue,
                    latitude: yValue,
                    wkid: 4326
                              geometry: busStop,
                else{
